Hi,
I have a Mitsubishi DLP and everytime I try to turn the TV on, there is a clicking sound and I also see an arcing / flashing lights from the power module for the bulb and there is no video.
Has anyone seen this? Please help!
Thank you..
Hi,
Thank you..
Copyright © 2020
depending on where the arc is coming from it could be as simple as the ;amp contacts have pushed back into where the ballast is located, or a bad connection on the lamp leads
Thank you. The arc seems to be coming from a component labelled FS1 on the board that supplies power to the lamp.
