KP-57HW40 PROBLEMS
johncharles
KP-57HW40 PROBLEMS
  I just replaced 2 convergence ic  model# STK392-570 & 2 5amp pico fuses, on my Sony projection TV Model # KP-57HW40.  The color looks good now, the problem I'm having the colors are not matching up, like their over lapping each other.  I reseted my tv to factory settings but still have the same problem.  Can you help me correct this issue.  Thanks in advance...  Do you believe the IC are defective? Do I need to add special code to the TV?  Need expert help..
slinteriors
Did you check the two 5 amp
Did you check the two 5 amp IC Protectors on the G board? They will often blow when the ICs go out. They look like picos except theyre grey
