Here is where consumers get bogged down with the terminology and
potential choices. Where once there was only the good, old-fashioned
25-inch tube TV, now consumers have the choice of not only a dozen
sizes from 26-inches to 73-inches, but also have to choose between
plasma, LCD, rear projection, and front projection.
The size of the television or video display device you get really
depends on the size of the room environment you will be using it in and
how close you will be sitting to the screen.
However, the decision as to what type of television you get is a little
more complex. However, no matter what type of television or video
display device you purchase, make sure it is high definition
compatible, as almost all geographical locations in the U.S. have
access to an increasing amount of high definition programming, either
over-the-air, cable, and/or satellite sources.
With specific reference as to whether one should get a
television-type video display vs a video projector, the main factor you
have to take into consideration is whether you intend to watch a lot of
television programs vs DVD movies.
nick
