Mitsubishi WS-55413 will not turn on
howzz
I did some searching and can not find what I'm looking for.  I have
a Mitsubishi WS-55413 that all of a sudden turned off and won't turn
back on.  When I press the power button the tv clicks like it wants to
turn on and the green light comes on then the tv shuts off and the
green light turns off.  I don't get the blinking lights.  I have the
service manual with the schematics but not knowing anything about tv
repair I'm not sure where to look.  Will you help?
howzz
ryan s
I have the same problem with
I have the same problem with my tv. did you find a solution
howzz
My solution was to have a TV
My solution was to have a TV repair shop fix it for $369.00.
Here is what he found and repaired.
CRT coolant leaked onto the signal board plus a bad power supply circuit.
Rebuilt main power supply circuit. Repaired horizontal output and pin cushion circuits. Decontaminated signal board. Drained excess coolant from all 3 CRTs.
