How to burn MOD video files with Menu?
1 post / 0 new
fishup2008
As we know,[b]iDVD[/b] is the DVD Burner which comes within the iLife package,it’s very convenience for us to convert downloaded movies and videos to a blank disc,but when I download the movies which contain MOD video format,it can’t convert MOD video files to DVD,especially when I want to create DVD menu.With the recommendation of my friend,I learn a dvd burner software named Mac DVD Creator,it can perfectly burn/turn/convert MOD video files to DVD(create DVD from mod video),also it Provides a highly customizable DVD menu.
Tips:
1.What are MOD files?
.MOD files are JVC's implementation of MPEG-2 transport streams, similar to a VOB file on a DVD or the M2T files used on Sony hard drive camcorders.
A MOD file contains a set of instruments in the form of samples, a number of patterns indicating how and when the samples are to be played, and a list of what patterns to play in what order.
2.What's DVD Menu?
DVD Menu is a menu of your DVD Movies. It will list the main process or the chapter details of your DVD Movie. DVD Menu has very small size based on its C++ programming. DVD Menu will pop up immediately after you insert your DVD disc into DVD driver.
Below I will share you the step-by-step guide on how to burn MOD video files with Menu.
Step 1:Download MOD to DVD Burner-DVD Creator for Mac for free: Then install and Run.
Step 2:Click the Add button to load the downloaded MOD videos on your Mac.
Step 3:Click the Edit button (the first button from the left) to edit video(video trimming, video cropping and video effect settings.)
Step 4:Creat DVD Menu
1.Click the Menu button on the lower right corner to customize your DVD menu. There are different styles of built-in templates, frames and buttons for your choice.
2.If there are some lines, pixels, mosaics or stripes on the picture, you can choose the suitable option from the interlace drop-down list to adjust the picture. The available options are: Repeat Odd, Repeat Even, Odd Interpolate and Even Interpolate.
3.Customize your DVD menu: customize Thumbnail or Background Image by selecting picture from your hard disk to replace the former one, and click Customize Sound button to add Background Music as your like or click the Remove Music button to remove the added music.
4.Customize thumbnail: you can choose a picture from hard disk as the thumbnail image of a title by clicking the Customize Thumbnail button to add it.
5.Customize Frame and Button or adding text: click Frame or Button to apply other templates; clicking Text, typing words on the Text Editing Window and adjusting the text effects as you like.
Step 5: Click the Preview button on the main interface to preview your DVD project.
Step 6:After you choose the correct DVD disk and the suitable video quality, you can click the Burn button to set burning settings and burn your DVD project(Burn MOD to DVD Mac). There are three output options: DVD, DVD Folder and ISO File.
