Hi Everyone!
I had a call today from a customer who is trying to use a webcam with her PC. OS is Windows Vista. Customer has successfully installed the device driver for the webcam. When customer clicks on AMCap icon on the desktop, however, the error message, "8007045a: Cannot create video capture filter", comes up each time. I walked customer through the steps of disconnecting the USB cable from the webcam, rebooting the PC reconnecting the USB cable to the webcam, but the same error message keeps coming up. Has anyone else had the same experience with a webcam?
Thanks for any suggestions you can give me!
Thomas
8007045a: Cannot create video capture filter...it is the same error am getting when i want run my webcam...plz help me out...
May 18, 2009
Hi!
I recommend that you access the following website and read number 2. It gives a step-by-step description of how to resolve this type of error message. There is valuable information too on how to resolve other PC cam error messages:
http://noeld.com/amfaq.htm
Let me know if you found this site helpful or not.
Hi Tech,
I did all as you said ...
At least I ran the webcamdiag programm:
Status
Driver not registered with Netmeeting (possible black border)
Video capure initialization failed
Can u help???
Thx in forward from good old Germany ... :-)
Hi Tech,
I did as u told us ...
At least I ran through the webcam diag programm:
Device and Driver status
The USB device enumeration failed (Code0)
Status
Driver not registered with NetMeeting (possible black border)*
Video capture initialization failed
What can I do?
Can u help me?
Thx a lot
Matthias
hey thanks yaar i got the same error but seeing that website i cam to i didnt select USB video camera but the prob is when i minimize r close it again the selection is gooing to google camera adaptor 1 wht to do?
you can´t press too fast .we haven´t get the image yet!
First of all connect the webcam to your USB drive. Check in the Device Manager (i.e. Right click on My Computer, select Properties, select Hardware, select Device Manager tab) whether there is any "?" mark on > Other devies > USB Device. Click on the "?" mark and click the "Reinstall driver". You will be taken to Installation Wizard. Select the option to install from a known source and click on Next. Select the installation from CD Rom or Floppy Drive and click Next. Computer will automatically take up the driver from the CD Rom and you will find your webcam is accepted by computer. Then ENJOY................
Hello Thomas,
I have the EXACT problem and its not going away!
I got the same results as Mattias did above.
I have a hpdv6000 win xp sp3. the integrated webcam driver was reinstalled and i get this message. bought an external webcam and installed the drivers from the cd and installation went fine and the computer recognizes the webcam but when i open the amcam i get the same message!
so this is not a webcam issue really something in windows.. can you please give me some suggestions?
Thanks so much
Hello,
I have the same problem Mr.Matthias mentioned above...
anybody plz help.
Thanking you.
hello hello
mijn webcammetje gaat branden boven op de pc, maar geeft geen beeld.
fout error 800704a cannot create vidio capture filter.
wie heeft het antwoord,ik wacht af.
met vriendelijke groet ejsmit@online.nl
Hello,
Even i am getting the same problem as "8007045a: Cannot create video capture filter" when i am trying to connect my webcamera to Pc. and my OS is windows XP sp3.
So,Please if anybody can help me out
Mesmo que já tenha resolvido o problema, vai a dica: Clique em ok na segunda tela que aparece, em seguid, clique em device e troque para o nome da sua câmera. Este erro ocorre quando a opção Google camera Adapter 0 está marcado.
Even if you have solved the problem, go to tip: Click ok on the second screen that appears, in Next, click and change to the device name of your camera. This error occurs when the Google camera Adapter 0 is marked.
yeah! Vipin thanks to your instructions I now have a working camera(Toy PenCam). The resolution is horrible will try to figure it out via the PC as there are no buttons for that on the device. @@@
