i have the ws 65819 chassis 18 the set has no picture quality problem after a half hour or so it shuts off with the 2-3 error code after set cools down it plays fine for awhile then the shut down occurs again found two bad caps on power board 150 volt 470 and 50 volt 4700 replaced them but the situation is the same
please help if you can [email protected]
