another phillips convergence issue no cross!
sandyman
Hello folks, I have a phillips ptv910 55" that has some issues. The picture is hazy and haloed. When i attempt the blue convergence there is only 1 crosshair present. I changed the ic's and I think all of the related resistors. If anyone has a solution for this it would be greatly appreciated. Also if some one could give be the exact resistor numbers that should have been changed, so that I can be sure I got all the bases covered in that department. I am no tech, just a tinkerer , but if someone can detail me some directions I can pretty well follow them.
thanks
John
Alnp
Type coolant contamination in
Type coolant contamination in the search box above, there is a lot of related info. Pull the front or upper back and look into the tubes.
http://www.eserviceinfo.com/downloadsm/31726/Philips_PTV910.html
imsokool
I have read about the coolant
I have read about the coolant contamination , but I didn't know if that could cause the abcense of the second cross on the blue convergence.
