daewoo vcr
5 posts / 0 new
rocketman
daewoo vcr
hi, daewoo model DV-T5DN. this vcr went dead, blew 2 amp fuse. upon checking found the main switching transistor shorted. does anyone know where i can purchase it? the number is KTC 4521F.ive done a google search with no sucess.  thanks pg
mrgart04
you can find the part here as
you can find the part here as well as the data sheet
http://www.digchip.com/datasheets/parts/datasheet/598/KTC4521F.php
Bright Apollo
thank you for your input, btw
thank you for your input, btw, the reason the transistor shorted, 68mfd/250v cap was open. regards pg.
mrgart04
you also should make sure
you also should make sure that there are no bad diodes from the dc leak , and that resistor values are within the excepted range
If you need anymore help , just post any test results you have , I just got done rebuilding a power source (atx) for my computer( was freezing up ) and found that they have been putting in these cheap capacitors ( teac ), and I have found that they are in alot of devices and they don't always show signs of failure , but they are failing , so just replacing any of these type brand of caps( teac, kc) will help the circuit to last longer and run better.
Bright Apollo
hi repairdude, regarding the
hi repairdude, regarding the switching transistor ktc4521 which is rather hard to locate, i used a 2sc3890. i added a heatsink, it seems to be working ok. thanks for the heads up on the bad caps. pg
