If you can help me resolve this issue then I would not have a problem donating money for your knowledge.
Just to let you know I have already tried resetting the convergence to factory default, doing a system reset, an A/V reset, checked all connections on all boards twice, and left the television both powered on and off for periods of time. Nothing has worked thus far and I need expert advice.
I do see a message when I switch to the DTV input channel that says: Check connections or power, The connections for RGBHV or YPrPb may be invalid. Of course I checked these connections and I see nothing out of the ordinary. One last note is that the scrambled screen appears on every single device station(Input 1,2,3 Comp 1, 2 DTV1).
Any insight into this would be so greatly appreciated. I have included some images of the problem and have more available if necessary. Thanks in advance.
Images
1. First scene from The Dark Knight
http://tinypic.com/view.php?pic=zogyuo&s=5
2. Image of the TV menu on a blank input screen
http://tinypic.com/view.php?pic=6r7ei1&s=5
3. Close up of the Joker(lines clearly visible on face and jaw)
http://tinypic.com/view.php?pic=a460px&s=5
