Odds are you have a bad inverter board . Also check to see if any of the capacitors in the power supply are going bad . The caps tend to buldge at the top of them . Good luck , james
jsf2323 said: Odds are you have a bad inverter board . Also check to see if any of the capacitors in the power supply are going bad . The caps tend to buldge at the top of them . Good luck , james
Thank you for your response, i'll let you know how things turn out.
Also can you send diagram and or instructions on how to fix.
