Curious,
What is the difference between the different STK392-nnn IC's? I assume from what I read is that the main difference is the higher numbers are later rev IC's with higher temperature ratings or better stability or something else that makes them better.
I know it's dangerous to make such assumptions but typically an IC manufacture will use this type of numbering system for IC's within the same family. (Or at least they used to when I was in that business) If this is so, an STK392-180 should sub fine for an STK392-120 but not necessarily visa versa. Am I correct or all wet when it comes to this IC family?
Blobby
