philips 60in 60pp9202/17f convergence issue
1 post / 0 new
nascarfan
   had   bad   ic  chips  and  two  bad   resistors    the    other   10   6.8oms   resistors   looked  ok   and   checked  them  oms  meter   in   the  board   they  read  4.3  oms  well  i  put   convergence   board   back   in   tv   i,m   able  to   adjust    red  &blue   convergence   but   the   multi-point  wont  adjust  correctly   it   seams  the   vertical  &  horizonal  is   a   miss   i   have  the  other   new  resistors   should   i   go  back  in  and   replace  them   also ,   had   same   promblem  last  year   with  bad  ic  chips  &resistors   replaced   ic chips  ( chips  where  aftermarkets  come   to  find  out ) turned   tv   on  and   adjusted   red  -  blue  and  both  multipoints   with   the   remote   perfectly ,   but  not  this  time   any  ideas ?    nascarfan
