I have a Phillips 60p8342 chassis #ptv 916 when you plug it in and turn it on red power light is on solid no flashing you can hear it click nothing else no sound or anything you then can not turn it off hitting power button. When you unplug it and plug it in power light is off till you hit power again. I have checked all the fuses and they are fine. Thanks in advance if you might have a solution Bob
This could be many things, unplug power and look closely at the boards under the "drip line" of the crt rack for coolant leakage.
Troubleshooting a TV For a Dead Condition by Larry Dillon:
http://www.techlore.com/article/14476/Troubleshooting-a-TV-For-a-Dead-Co...
the manual for Philips 900 series chassis is here:
http://www.eserviceinfo.com/downloadsm/31726/Philips_PTV910.html
