Fax Voip is a virtual T38 fax COM port for your SIP Network. You can send and receive T38 faxes via SIP networks with standart fax soft.
What is FaxVoip? From the prospective of your fax application, it is a fax modem. Your application is connected to FaxVoip via standart COM port interface. FaxVoip installs virtual COM ports in your system. You can setup your fax program to work with FaxVoip COM ports. You can also install 'Standart 14400 bps modems' for FaxVoip COM ports and use your TAPI Fax application with modems. From the prospective of your SIP network, it is a SIP client with T38 Fax support. With FaxVoip you can send and receive T38-faxes without any hardware, using your favourite fax program or fax server. You can use FaxVoip with your IP-SIP-PBX and with your SIP-T38-Provider. FaxVoip support from 1 to 100 fax lines simultaneously.
You can download free trial from
