Sony KV34XBR800 with dreaded 6 blinks
1 post / 0 new
weedhopper
I have a Sony KV34XBR800 with the dreaded 6
blinks.  Sometimes I could get the set to come on by powering it up a
few times.  When it doesn't come on, I've seen 4 blinks, followed by 6
blinks; a few times 7 blinks.  But usually, it goes right into 6
blinks.  I did recall once that the picture got bigger and then faded
off, all within a second, before shutting down.
I've gone
through the forums and it appears that the most common fix has to do
with the D Board's IC6501 and IC8002.  So I replaced both of those IC's
and the set came on.  The TV was turned on and
off at least 6 times that day and it worked fine.  But the next
morning, it was back to 6 blinks.
When I had the D Board out, I
inspected the solder joints and they all appear to be fine; bright and
shinny.  I found a 33mfd cap whose top wasn't quite as flat as the
others so i replaced it too.  Don't know if that cap was bad or not as
both the new and old one reacted the same when tested with a DVM.  The
cap was only a $1.
I had an extra MCZ3001DB.  Figuring that this
IC has a pretty high failure rate, I swapped it for the IC6501 and then
for the IC8001, but I still get 6 blinks.
I'm not ready to
retire this set.  The picture is exceptional, when it was working.
Replacing the D Board is no guarantee.  Besides costing a fare sum of
money, it isn't as satisfying as fixing the D Board.  That's assuming
the problem isn't elsewhere.
Can someone guide me through to resolving this 6 blink problem?
Thanks    [email protected]     Sony KV-34XBR800
