Mitsubishi wd 52525 weak picture
airwright
A mitsubishi wd 52525 dlp tv with a weak picture, i suspect that the lamp needs to be replaced even though the idiot light isnt lit. The picture is very weak with no luster.  Also is there any way i can clean the insides of the tv the last time i changed the lamp there appeared to be dust on the prisoms or mirrors that i could see inside of the tv with the lamp pulled out.
When i bought this tv four or so years ago, it was just great, now its just another tv fading away    what can i do or have done?
sound ik you have a bunch of
sound ik you have a bunch of bad capacitors in your set. most likely in the FMT board and maybe the power supply. would you like a list of bad caps to change? Maybe it will help but a chance it will not. e mail needed to send to you.
Doin12volt
larry, Do you have a copy of
larry, Do you have a copy of the LIST of bad 52525 caps? I could include this with the document I was talking to you about, (plus Id like to have it to compare against all of the ones I am about to change out as well)
Lemme know!
