Mitsubishi VS-6043 Blue lines - Help?
steveb2584
Can you help me with a problem? I am starting to get some blue lines running kind of vertically through the screen, visible when there is a dark background. Can you tell me what this is and can it be fixed?
I have to say this has been a good TV, this is the only problem Iv'e had with it since I bought it maybe 13-14 yrs ago.
slinteriors
check the resistors on the
check the resistors on the CRT drive circuit board on the neck of the blue tube, usually onre of the resistors near the screen control will be open causing that.
steveb2584
Thanks for the help, I will
Thanks for the help, I will check that.
Steve
