mits ws55311, error 2-2
kayleigh0302
I have a mits ws55311 that worked fine, no picture problems or anything else. All of a sudden one day it shut off without notice, when I turned it back on, no picture came on and the green light stayed on for 3 sec  then clicked off. when I checked the error code it indicated 2-2 short protect. Since then I've heard many things, but when I took chassis out and had professional check fuses (7) he found the 1 - 5 amp fuse blown, he replaced it.   he checked the diodes and everything else was ok, I put it back together and turned it on - the same thing happened.  Can someone please help.  I had no picture problem so the IC seems not to be the culprit.  I live in the middle of nowhere and no tv repair people will help with a mitsubishi.
slinteriors
On that model check the two
On that model check the two pico fuses F9A04 and F9A05 if those are open the convergence ICs are the problem. They are green pico fuses both 5amps
