I am having trouble with my WD-62525 DLP television. I do not know if is related to the other blinking green lights or not.
After plugging the TV in the Timer Light flashes for about 30 seconds. Try to turn on the TV and the Power Light goes green. After about 1 minute the Power Light goes out, and the LAMP light goes solid red. I had replaced the lamp about 6 months ago. I looked at the lamp and it appeared okay. Turned on the set with lamp cover off (holding down switch with screwdriver), and the lamp briefly turned on and then went out. This was followed by the LAMP light going red.
Any help is appreciated. If someone has the documents that Larry has been distributing my email address is [email protected] or [email protected]
BTW: Larry, my prayers are with you. My father went through treatment and I know it's rough.
