After reading Larry Dillons article on "Replacing Convergence IC's on a Mitsubshi TV Set." I set out to replace the Convergence IC.
This is what I found out so far: I've tested the 2 Pico 5amp fuses for continuity. They both tested okay. I then tested R8C45 and 46 resistors. They both turned out bad. The others test out good.
Does this meen that the Convergence IC is bad?
Any suggestions?
FrankD
