Hi, I have a Sony KV-30HS510 that after a recent reconnect is displaying a skewed video picture.
When displaying the image from my media PC via DVI the picture is tilted and non-rectangular. It tilts to the left and the top-right and bottom-left corners are pulled out while the opposite corners are pushed in towards the center.
The tilt to the left is beyond the ability to adjust in Setup and naturally making this adjustment tilts other inputs to the right! The other inputs appear to be displaying normally - it is only the DVI that is a problem.
Is it posible this is the result of a connection loosening in the DVI port? (It received some pressure when the TV was slid towards the wall from the DVI cable getting pressed against the wall.)
Is there a way to access higher function image adjustments? Like a CRT monitor would have?
Has anyone seen this? Anyone have a fix?!
Hopefully, Dre.
As I think about it, I suspect that the majority of the problem stems from the skew. Fixing that seems like the priority - then see where the tilt situation lies...
Dre.
