Does anyone else have this problem? When using the HDTV connections, I get a green background and barely get any red or blue. If I switch to any other connection, the color is fine. I've adjusted the color scheme but it still has no affect. Has anyone else had this problem, if so, what was the fix. I pulled the back panel and found two possible circuit boards that could be the cause but I'm not electronically capable to test them. Any help given is greatly appreciated. I can be reached at [email protected], Thanks
Mitsubishi WS65611 green color dominant
Fri, 07/04/2008 - 19:49
