This sony kp 61v80 made in 1999 was working fine. Then I went to turn it on and nothing happened. No picture, sound , or any indication it's plugged in except the light. The standby light stays lit the second I plug it in. It never flashes and just turns on the second I plug it in and stays lit. No response to any buttons on the Tv or the remote. Anybody have any ideas to save me from this insanity ?
Ok, I took the back panel off. About center front of the circuit board is a 3 legged chip # d2578 9f4. Behind the metal heat sink is a little blue 2 legged guy. It smokes when I plug the TV in for a couple secs then stops smoking. Could it be this needs to be replaced or something else is loading it up ? Hopefully this helps someone help me 8-)
[quote]
On 2008-07-04 23:22, srtdunk wrote:
can u get the TV on at all if you use the remote function?
Hit DISPLAY, 5, Volume -, and then power in succession. I was having the same problem, but TV should turn on at least and give you some error codes.
Not the smoking problem though. Just no picture or sound
[/quote]
Ok, hitting those buttons does nothing to the TV. I, however, did get an extention cord and plug it in while I could see the light. It does flash once, then stays lit.
