Mitsubishi WD52725
steve jn
Mitsubishi WD52725
I have a problem that is similiar to some other posts,  but have not seen this one.  My WD52725 will not power on.  When I press the power button , the green led comes on and after about one minute the red led comes on. (this is the led that says I need a new lamp).  The lamp is only one week old,  but I changed it anyway.  Same problem.  I did get the set to power up yesterday one time and cannot get a picture from any source.  Tried vcr, sat receiver, etc.  Also when I try to turn the set on I don't believe the lamp is coming on at all.  So this morn it is back to the red led on and will not power up.  Is part of the problem the power supply?  I understand two caps may need to be changed(3300UF).  Although I don't know if I can do the work myself,  If I can narrow this down to where I can remove the power supply or whatever is necessary,  I can take it to have the caps checked and replaced if necessary.  Any help would save me from disaster.
By the way,  I have cleaned the optics on this set a couple of times and if that info would be helpful,  I would be happy to share that procedure.
Thanks for your help
Steve
Dave MacK
hello sir: I have a
hello sir: I have a Mitsubishi model 52725, it has the infamous blinking green timer light . can i get the part to fix this , if so pls give me the info on how to purchase what i need ... Thank You Dave Mack
