need help with "protect" mode showing on my receiver
4 posts / 0 new
marshallmark
marshallmark's picture
I have a techwood 400 watt home theater receiver model number PLR85. One day the receiver shut off and displayed "protect" on the front panel. I like the system and due to a divorce I cant afford another system for a while. We are located in arizona on a ranch and i have to say the device was loaded with dust bad. I opened it and cleaned out as much as I could but the, "protect" is still being displayed. Any ideas what to do? who to call? what needs to be repaired? etc... Thanks mark
dans_repair_service
dans_repair_service's picture
The protect message indicates
The protect message indicates that the output section has a problem. The protection state prevents further damage. If you have no experience in electronics repair, any service shop should be able to help. If the output transistors have failed, figure on $8 for each one (will need at least 2). Supporting part may be needed as well so the total parts cost will probably run between $25-$35. Add in your local labor rate for the total repair cost.
Dan
cochita
cochita's picture
i have a techwood 400watt
i have a techwood 400watt home theater reciver model number plr85 when i plug it in i get a green on light but it wont turn on or off what should ii do
blondeinsomniac
blondeinsomniac's picture
I have a Techwood PLR85 that
I have a Techwood PLR85 that was working good until an unauthorized user (my friend) decided to hook 2 more smaller speakers up to my unit. He did it by twisting both the Big speaker & the smaller speakers wires together and then inserting them into the large speaker jack on the back of speaker and to the back of the receiver unit. When I turned it on it wouldn't work. There wasn't any sound at all from any speaker/any channel. I do remember the unit displaying briefly a message
