My computer screen has a black circle at the top left corner
15 posts / 0 new
dbw
dbw's picture
I splashed a little water on my computer screen one night and of course there are some bad spots at the bottom of the screen where the water actually touched it. But a day later a black circle appeared at the top left corner opposite where the water splashed. Does anyone know why and is there anything I can do?
tina1965
tina1965's picture
Hi,
Hi,
I have noticed om of my screen n my ell laptoptat I have two black circles at the bottom of my DELL laptop.
I don't think I have dropped water on it. The circles are getting bigger.So,I am getting worried? oes anyone have any suggestions?
helpmetoo!!
helpmetoo!!'s picture
I have the same exact problem
I have the same exact problem!!! I accidentally got water on my screen a couple days ago, turned the computer on the next day and there was a large black circle in the upper left corner of my monitor. And it seems to be growing slightly larger everyday!
Did you end up getting any help with this??????
Please let me know, as this is a work computer and not my own personal property :/
Thank you!!
louisee xx
louisee xx's picture
i kind of have the same
i kind of have the same promblem, but i dont think i spilt wqater on it.
but i have a crack on my screen and i think it is because i have shut the lid down to hard and now it has 9 BIG circles over the screen and i am scared incase it goes all over the screen what do i do ? :S
mackie28
mackie28's picture
your computer screen get wet
your computer screen get wet sir.
it seems that the water penetrate inside.
as a cellphone technician, my solution there is to wipe the screen rapidly it takes long to do this. but that is the only solution that i know to dry the water inside the screen.
i hope it helps u for my comment. thanks..
divadown
divadown's picture
I have the black dots too!!!
I have the black dots too!!! And they are growing!! At first I had only two. Now there are five!! And there are black growths at the bottom of the screen that look like they are going to grow into more black circles. I am not sure if this is water. Not that I know anything about hardware. Mackie28 I tried to rub the screen as you suggested. I am lost. I am starting to think this is a defect in my dell laptop. Any more suggestions out there??
Patriot100
Patriot100's picture
I told her NO! Do NOT clean
I told her NO! Do NOT clean the monitor when you clean up the house. But what did I see on my monitor? - that's right - water streaks. And the next day, budding purple and green lines began to grow on the lower right hand side of the monitor like those magic crystals you throw into a small bowl of water. Then like a slow motion nuclear explosion, a black ball began to grow eclipsing the lines and it hasn't stopped growing.
I'm not sure if I want to try wiping the screen rapidly, I might try a hair dryer. If that doesn't work I will try rubbing it. If that doesn't work I'll try fixing it by buying a new monitor.... :/
tronracer
tronracer's picture
me too !!!!!111 the exact
me too !!!!!111 the exact same thing happend to me except the rings of water on my computer r growing and they r more clear
venom96737
venom96737's picture
If its an LCD screen you have
If its an LCD screen you have dead pixils the only real fix is to replace the screen.
Brenda Starr
Brenda Starr's picture
I don't have black spots but
I don't have black spots but I have cracks that have spread. Is this something that I can do or do I need a professional? What about replacement cost? Any thoughts?
fr
fr's picture
Hi what happended patriot100
Hi what happended patriot100 did your monitor survived or did you get a new one.let me know
fr
fr's picture
hi ,
hi ,
i wanted to know whether  the problem got worse or you got it repaired
bye
BLACKSID
BLACKSID's picture
wow, just found this out.
wow, just found this out. thought i was being spyed on by the government. im already in trouble from the girl'y shows/ sites. LOL
marshafaith606d
marshafaith606d's picture
OK WHEN THE COMPUTER SCREEN
OK WHEN THE COMPUTER SCREEN GOT WET YOU HAD TO DRY IT OFF SO YOU GRAB THE MONITOR AN IM SURE UR FINGERS WERE HOLDING IT WHICH ISNT THAT LIGHT SO YOU HAD TO GRIP IT WITH UR FINGERS, WHICH POPPED PIXELS... AN NOW U HAVE A FINGER PRINT THAT LOOKS LIKE A SPOT????
JUST SAYING????? MY CORNERS ARE WHERE I GOT THE DAMAGE FROM CLEANING IT... I HAVE FINGER PRINTS IN 3 CORNERS WITH A WHITE LINE THAT COVERS HALF THE BOTTOM OF SCREEN, EXACTTLY HOW I DO CLEAN IT, SO MAYB U DID 2???
GOOD LUCK
camp deb
camp deb's picture
We were having a water ballon
We were having a water ballon fight....one of the ballons splashed on the computer screnn. Now it looks like water running down the screen!!!! HELP ME MY DAD IS GOING TO KILL ME!!!!!!!
