My Panasonic 52" rear projection tv will not turn on when I came home from work and it might have been from a blackout. The TV does not turn on at all no light red or green. I believe its just a fuse. I opened up the back of my rear projection tv to locate these fuses. I found 2 on the circut board of what seems to be the right shape and size but....the clear glass that the fuse usually is s covered in white. Now also the 1 fuse near the pwer cord attached to the circut board has a clear plastic tape around it making it tough for removal.
Is this the correct fuse? How many fuses are in this tv? ANy help would be great.
Thank you
the Model is PT52LCX66 and the Main AC Fuse is F1001 6.3A @ 250Volts
Is the Power Control PC board for this panasonic model PT52lcx66 the main circut board thats green which is approximately 12"x12" and where the main power cord plugs into? There are approximately 5 different plugs that goes into this board. Is it part number LSEP1207A1?
Thank you
What is the part # for the power supply pcboard for this model TV? I really need this help and cannot find it from anyone. Or if there is anywhere i can find out?
Thank you
