Sony KF50XBR800 blinks 34 times in standby mode
9 posts / 0 new
jmar1174
 Sony KF50XBR800 blinks 34 times in standby mode. I replaced the lamp and the tv seemed fine for a few day and them it started all over again. I really need help as my sports world is turned up side down. Does anyone know what else could be causing this issue it is really driving me nutz
Dwray
3-4 blinks 3 = Lamp Cover is
3-4 blinks 3 = Lamp Cover is not attached securely 4= Fan1 or Fan2 is not working I would first remove the lamp cover (Door) and reinstall if TV comes on Replace Lamp Cover Switch S8001 part# 1-570-245-11
jmar1174
Thanks but it is actually
Thanks but it is actually blinking thirty four consecutive times not 3 or 4 and i did replace the lamp/bul about about 2 weeks ago. Any other ideas?
Dwray
I didnt say replace the Lamp
I didnt say replace the Lamp again ! I said Remove the lamp Cover Door and reinstall it there is a SWITCH for the DOOR and if the switch is not Closed or defective the TV will not Power UP
Dwray
Service Manual only lists 3 , 4, 5, 6 , 9  Led blinks  for Self Diagnosis
jmar1174
Thanks Dwray i will try you
Thanks Dwray i will try you suggestions.
ARAY
The screen on the KF-50XBR800
The screen on the KF-50XBR800 (LCD Projection TV) will turn off and the red standby light will blink 34 times before it comes on again. It shuts off again after 2-3 minutes. Any ideas ??
pacorrom
he is on the target on your
he is on the target on your problem ,i had same problem and it was the lamp door ,i did make sure the lamp was instaled correctly and the door was making good contact and my problem was resolved .....
abby11
Sony KF50XBR800 blinks 9
Sony KF50XBR800 blinks 9 times in standby mode after i replaced the lamp. what do you think is causing this ?
