I had a convergence issue and have since replaced the ICs and fuses that needed replaced. Now, when I am trying to replace the D board I realized that I do not remember which plugs go where. I have a general idea based on length of wire and obvious size of plugs but specifically there are 3 smaller size plugs on the right hand side of the board (when set in the tv). Will it damage anything if I plug them in incorrectly or can I use trial and error until they are plugged in correctly?
NO DO NOT PLUG them in if Your not 100% sure if pluged into wrong socket it can do some major Damage ! Look on the Board and post the socket numbers that you are unsure about .
Thanks for your help. I followed the wires back to see which red, green, or blue they went to and was able to plug them in correctly. Thanks!
