STK392-110 = 3amps Max Voltage +/- 38v STK392-120= 4amps Max Voltage +/- 44v STK392-150= 3amps Max Voltage +/- 38v STK392-180= 3amps Max Voltage +/- 38v STK392-010= 5amps Max Voltage +/- 38v STK392-020= 6amps Max Voltage +/- 44v STK392-040= 7amps Max Voltage +/- 50v STK392-560= 5amps Max Voltage +/- 44v STK392-570= 8amps Max Voltage +/- 50v Use The STK392-120 to replace the STK-392-110 , STK392-150 , STK392-180 Use The STK392-040 to replace the STK392-010 , STK392-020 Use the STK392-570 to repalce the STK392-560
STK392-XXX Spec's
Sat, 05/31/2008 - 16:52
STK392-XXX Spec's
I have a KP-57WS510 TV which has a red color convergence problem. I am about to order 2 of convergence IC. Should I have to order STK392-570 instead of STK392-560?
Yes, you order those from Here http://www.electronic-repair-kits.com/STK392-570.html
Thank you for the reply.
Is there any advantage or reason to have STK392-570 than STK392-560 for my Sony KP-57WS510 TV?
I have downloaded a service manual, and it said the convergence chip on D board is STK392-560.
I look forward to hear from you.
Thank you again.
The STK392-560 is only rated at 5amps The STK392-570 is the same IC but its rated at 8amps which will run cooler and last 2-3 times longer MFG use the cheapest part they can to cut cost and Yes the STK392-560 will work Just Fine But will burn out much faster then the STK392-570 which does cost more Because its More Heavy Duty
Forgot to add mcminone.com has them onsale for $15.69 But you must use Soure code # WR805 at checkout or when you call to get sale Price if not they are $19.95 reg price .
MFG only really care about there TVS lasting the First year So if the STK392-560 will last 2-3 years and saves them $4 per set over using the more expensive STK392-570 and they make 2 million sets a year thats a saving of $8 million dollars Thats why they Use the STK392-560 & not the more Heavy Duty longer lasting STK392-570 SO if your 560 has burned out why not spend the extra $4 Each for the Better STK392-570 that will last 2-3 times longer or out last the TV !
The last MCM IC I received had a T1 on it. that means it was made in China.! I use only original Sany IC's from http://www.electronic-repair-kits.com/index.html
Never had a problem with the STK's i got from MCM were all Original Sanyo Have to check the 12 i just got Friday .
Never Heard T1= China Lot of Guys go buy the 4 diget or 5 diget Code or by the Code numbers The TRUE test I have Found to tell Generic's from Originals is the acetone test I have got some China made STK that were Perfect Copy of the Sanyo STK Perfect lettering & Correct code # Fooled a lot of Techs until I did the acetone test and showed they were Generic's
PS: Just checked the 12 i got from MCM friday all are originals .
Just check electronic-repair-kits there price on the STK392-570 at $16.95 is GOOD ! The STK392-040 at $13.95 thats a GOOD Price to But The Stk392-120 at $15.95 Is High There $5 shipping is Good to just wish sold more Parts like LCD/DLP Lamps , HV transformer ETC . We are replacing about 6-8 lamps a week got to order more Lamps tonight Next Stop Tritronics web site .
Here a picture of a Original Sanyo and A Generic see how Both have a 5 number code Lot of People think china made STK will only have a 4 number code & the Sanyo will have 5 as you can see Thats not a good way to tell them apart Look at the Lettering (STK392-120) on the Sanyo its stright with the mounting Holes NOW look at the Generic the Lettering is BELOW the Mounting Holes Plus look how Nice and clear the lettering is on the Generic thats because its Painted on which will rub off with acetone real easy .
Dwray and Larry, thank you for the information.
Even though "Made in China" will work as original, I will order the original Sanyo ICs for safe side.
I have one more question that lots of people are mensioning to buy some pico fuses and convergence registers along with ICs in case of needs. I cannot find those items @ electronic-repair-kits.com. Does anyone have the url for those items?
you can check the Fuses now to see if any are open Check PS8001 , PS8002 , PS8003 , PS8004 , PS8005 & PS8006 all are ON D Board & are 3.15 amps Pico PLUS check PS5002 & PS5001 ON G Board they are 5amp as for resistors check all the 4.7 ohm 1/2watt near both STK there will be about 15 of them per stk color band will be yellow purple gold ALL can be bought at tritronicsinc.com the 3.15amp pice fuses part# 153359542 are $2.00EA the resisters Part # HW4D7-10 come 10 to a pack for $2.23 a pack
Hey - Muchos Thankos Dwray! It was pico sites PS8001 and 2 that we're burnt. I had replaced the chips, and half of the problem had been fixed, i.e., the Red and Yellow - but the Blue was still bad. Those two pico fuses were bad. Thanks for naming the exact places to check - I had checked all of the resistors, and they were fine - but I hadn't checked the yellow Pico fuses carefully! There -should- be some way to rate your posts on this page so we can vote for the comments that were the most helpful....
It's funny - this is -such- a common problem, I would think that there would be people who would accept the old board and send you new or rebuilt ones!
