Hi all,
I couldn't find a downloadable manual for my Samsung HC-P4752W rear projection TV - and had to eyeball convergence adjustments. Could someone let me know what the dimensions are for the jig on 480 and 1080? I found a samsung manual for another 47 inch, but not my exact model. Is it likely going to be the same if nobody has the dimensions? Also - before I knew better - I forgot to write down the factory defaults for the convergence & nr menus in the service menu... haven't heard that one before, have you?? I did put the defaults in from the other manual and it seems to be ok for now.. ish..
Cheers
Geoff
