TV Shutdown issues WD62525
Bigmac
Some times TV shuts down after 2-3 minutes. Other times, it runs for hours. When it does shut down, it gives a RED LIGHT code 34. IF I unplug it, then replug and power on-it might run for the short 2-3 minutes, or even hours. Is it possible to get the service manual, and software updates for this set? Thank you in advance.
Gerry
Gerry, there are bad
Gerry, there are bad capacitors all over this set. If you leave an e-mail address, I will send you the repair documnts I put together for this TV set including the service manual. Good Luck, Oh btw, there are no software updates for this set.
Rib Breaker
Larry. New to this forum. I
Larry. New to this forum. I see that there are many questions on the Mitu 62525 lamp replacement and the blinking light/shutdown issue. I see that you have offered a service manual link. Would you be able to send this to me at [email protected]?
Jim
