I purchased this unit in 02, still funtions fine, however, the picture is getting dim, the only way to view
the picture is in the vivid mode...Question, as an old time tech i would instal abrightner or replace the tube.
This is an LED projection system can the LED mod. be replace and would the relate the problem. thanks very much guys :) you can email me at [email protected]
Excuse me? An LED Set?. Nope, I think you are mistaken my friend. This set is a simple three tube projection TV set. Have you taken out the front screen and tried to clean the mirrors and lens yet, Six years of dust and dirt can make any projection TV set lok dim and dingy. Good Luck
Thank you very much for your answer....I will do as suggested ty.....do the projection tubes cost effective to be replaced?
not really, they will cost you a couple of hundred bucks a piece then to replace thenm and maybe have other problems?
