replaced the convergence chips and pico fuses on my wt42311 and now I have great greens, reds and blues , but no white at all. The center crt looks bad, any suggestions, thanks
I took off back cover and the green crt doesn't turn on. I thought it was only whites, but it is green also.
I replaced the con. chips w/ new 110's and the bad pico fuse and now no green crt.
I relaced the con chips first w/ 150's and it worked for 2 weeks, then the pico fuse after that, so I went back to original 110's and a new fuse and now this ???
Explain in a little more detail please. What makes you think the green CRT is bad? That is the middle one by the way.
If you have a different problem after replacing the convergence IC, you must have a wire or plug out or shifted somewhere.
I looked for loose wires, nothing.
Lastly, the green crt is glowing at the base, but nothing hits the screen. No glow out the top. ????
btw, there was only one connection to reconnect, it was on the right side next to all the rca and antenna inputs
