I have had this TV for 3 years and put two new bulbs in [one each 13 months] in march the bulb went out again and I got a new one but it had no effect. When I turn it on the green light comes on for around 1 min then goes to red? I have unpluged it and same thing happens.
I pushed the buttons on the front and got a code 34 which I believe is for a bad bulb? If I could get a copy of the sevrice manual and the fix for the caps I would be in your debt. My email is [email protected] thanks.
This is probably the 2 3300uf @ 10v caps on the power supply board.
I will send you the directions I have to replace these capacitors as well as several others I have found bad in these TV sets. Also the very common capacitors that go bad on the Formatter(FMT board)Good Luck with the repair.
Larry, could you please send me the directions for the red light (Code 34) too?
sir i have a sony model no. kpfx432m91. oneday my child sudenly shut off the power by the front panel of the tv. after it hapen, i try to on but, i cant. the symptom that red LED blinks around 10 times after green around 6 times and television works 5 seconds after it goes stand by. i am requsting you to ps help me this is my e mail [email protected]
Can you please send me the directions, pic, diagrams or whatever you have, to change out the capacitors you mentioned above. Tried bulb, wasted my money. Thank you in advance. [email protected]
PS: My 52525 has blue screen with big whiter like blob in middle, no picture or sound.
