WD-62825 TIMER RED BLINKING LIGHT
5 posts / 0 new
hanser
A GOOD FRIEND OF MINE GIVE ME A MITUBISHI WD-62825 TV BECAUSE ONE DAY THE TIMER STARTED TO BLINK RED AND IT SEEMS THAT THE POWER SUPPLY COMES ON BUT THE REST OF THE TV IS NOT COMING ON WHAT CAN I DO IF THERE'S ANY TO FIX THIS PROBLEM. PLEASE ANY HELP WILL BE GREATLY APPRICIATED. THANKS.
Larry J.
Larry I posted a question to
Larry I posted a question to you in the fourms but I'll ask here too I have a WD52525 with a solid red light. I have replaced the bulb and it starts with a blinking green then goes to red. Any help with a fix and or manual would be great. email is [email protected]
hanser
MY TV STILL WONT GO ON AFTER
MY TV STILL WONT GO ON AFTER I HAVE REPLACE ALL THE CAPACITORS AT THE POWER SUPPLY, FMT BOARD AND DM BOARD , I HAVE CHECK THE RESISTANCE AT THE THERMAL SENSORS WHEN I CONNECT THE TV OR WHEN THE TV IS UNHOOKED AND I HAVE NOTHING WHAT ELSE CAN I DO GIVE ME AN IDEA. THANKS.
Larry, your problem is
Larry, your problem is capacitors in the power supply or the ballast circuit is bad.
hanser
WICH ONE IS THE BALLAST
WICH ONE IS THE BALLAST CIRCUIT? I HAVE PURCHASE ALREADY THE SERVICE MANUAL FOR MY TV , CAN YOU TELL ME HOW DOES IT LOOKS LIKE?
