The Power just recently went out I uplugged it left it unplugged all night and still would not power up I assumed it was the fuse as I tested it with a volt meter and got a zero reading I got the replacement fuse and still no power any other ideas would be greatly appriciated.
Steve
Well looks like the fuse may still be the issue I tested with my DMM and got no reading from it has to be blown will order another one see if it will work the fuse it uses is a T3.15 250V I called a electronics part stroe and the tech told me that it is a time delay fuse or slow blow (sounds nice ;-) anyways just thought I would put up the info see if it will be useful to others.
Steve
