I have a problem with a Mitsubishi Ws65813 (green blinking light). I read previous threads on this subject and want to contact Larry Dillon concernig the dm part number and or which components other than the caps need to be replaced as well as all value changes in caps. I have knowledge in electronics so method should not be a problem.
Leave an e-mail address and I will share with you the repair documents as well as the Factory Service Manual. Good luck with the repair.
Larry, I have the same issue with my Mitsubishi WS-65513. Blinking green light of death. Is there anyway you could send me info on how to fix the caps and where I could purchase them? Thank you in advance. If you are able to send any info, please send to [email protected]
Larry I too have the saem issue and need the repair documents mine is a WD-62525.
Thanks in Advance
So many people with the same problem. I have the WD-52525, and whenever I plug it in the green light continously flashes. I have read here alot that it could be the caps, but which ones. I have also read that Mr. Larry Dillon can send out some documents and the service manual. So I guess what I am asking is can Mr. Dillon send me a copy of the documents please? My email address is [email protected]. Thank you very very much.
Same problem here as well...blinking green light of death. Can I get the repair documents and factory service repair manual please?
thanks
aaron
