It could be a very common problem DM board. Unplug the set and if the light blinks for more then several minutes, most likely that is your problem. If the green timer light blinks for about a minute or so and goes out, then you have a power supply or sweep problem with your TV set. If the DM is bad, and if you call out t tech, the bill will be about a grand or so to repair. If you have any soldering skills or any experience working on solid state printed circuit boards you can repair the set for under 20 bucks. Good Luck
Kebra, the DM stands for Digital Module, If you leave an e-mail address, I will send the manual and the repair instructions to you. If this is indeed your problem, this repair could possibly save you about a grand or so, as the DM is an exchange part and is expensive. Good luck
It is not available to just anyone. Only an authorized Mitsubishi repair shop can get one. They do not make new DM's,They are rebuilt by Mitsubishi. I will send you out the repair direction . Good Luck
What does DM stand for?
And where would I get the schematic to locate this?
Thanks again
Kebra
Thanks Larry
What do you mean " an exchange part"?
thanks again for your time
PLease send me the same thing.
