I need to know where I can purchase the convergance ics and fuses for my KP-51WS510 sony TV? I have read some of the threads on this site and feel I can fix this myself. I have received quotes of anywhere from $200 to $400 to look at the problem. Was told by one person that it couldn't be repaired, but he would get rid of it for me! ( so would I for the cost to fix it). lol
All of your help is much appreciated!
You can get the original convergence IC's from here http://www.electronic-repair-kits.com/index.html and the pico fuses from here http://www.bluestar-online.com/5_AMP_PICO_p/5%20amp%20pico%20fuse.htm Good Luck
Where can I get a service manual for this TV. All of your help is greatly appreciated.
You can download one free at the techlore's tecnicians corner. A new service that is provided by techlore. It is located in the resources tab at the top. Or here is the link. http://www.techlore.com/group/2/list_downloads. Good luck
Thank you Larry!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Larry-
As I was removing the D board from the chassis, the small wire coming out of the flyback transformer broke off, there is about 3/16" pigtail now hanging from the end of the wire going up to the front of the TV. Can this be fixed or will I have to buy a new flyback transformer?
Waiting for good news!! lol
The number I get off of the FBT is 8-598-828-20 which on the link you provided in another post shows discontinued. Doing a search I found new and used. What do you suggest I do? I so need my big screen working again, 21" screen just does not cut the mustard, If you know what I mean????
Thanks a million,
Larry I was told to use stk392-570 because stk392-560 are no longer availabe. Is that true. Can 570 be used in place of 560? sony kp51sw510 Tv.
spike21-
I just bought the STK392-560's from electronic repair kits. There is a link above to that site. As for that being your problem that would be for Larry to let you know. Mine however was doing the same thing only with a blue and yellow haze on the left side.
Are you able to fix it bowat6969?
They are out of stock. Well I found at tcm module should be here in 2 days. I checked voltage to g board +15v is +17.5 and -15v is -14.5v. 21v seems ok its 20.5. 135v is ok. Is 17.5v too off? Is this mean pico fuse are good?
