Sony Rear Projection TV -- Need to move it
4 posts / 0 new
Moona
I have a 65" Sony rear projection unit.  About 5 years old.  Perfect condition.
 My problem is that I need to relocate it downstairs, and the unit is a bit too large to go down the stairs and through the door opening at the same time.
 With other units I've moved, I was able to separate the base from the screen, and move them as two separate pieces.   It was simply a matter of removing some screws around the handles and base, and disconnecting a ribbon cable, and the unit was able to be separated.  If I could do this with my Sony I would be in business.
 Is there a way to do this?  Or am I going to have to cut my door opening wider to make the move. Tongue out
Jay
I do not have a clue without
I do not have a clue without a model number. Most Sony 65" sets are NOT all the same. What is the model number?
Moona
Larry Dillon said: I do not
Larry Dillon said: I do not have a clue without a model number. Most Sony 65" sets are NOT all the same. What is the model number?
The Model # is KP-65WS510.
Thanks a ton!
Jay
I'm afraid this set does not
I'm afraid this set does not come apart in two sections. If you want you can see for yourself on how the set does come apart by getting the service manual. That manual is available from a new section here at techlore called the Technicians corner for free. Go to http://www.techlore.com/group/2/list_downloads
Good Luck.
