I've replaced the two convergence IC's (used STK392-180 for original STK392-110) and one blown resistor (2.2 Ohm, 2 watt). After that, I went through the user convergence adjustments but I still get double immages and green lines on mainly the upper right corner. Mainly, there's a static vertical green line on the right side of the screen which does not respond to adjustment. Is this an issue with adjusting the main convergence in the service mode. Thanks for any advice.
Service access code for Panason PT-51HX41E
Wed, 04/23/2008 - 12:52
