zenith model e44w46lcd yellow blotches on screen
4 posts / 0 new
kevco
kevco's picture
I have this zenith model that has yellow blotches on the screen.I heard it might be the light engine going bad.Does anyone have a similar problem?
kevco
kevco's picture
Thank you motvguy.Do you know
Thank you motvguy.Do you know where the light engine is located? Also do you know where I can get a service manual for this model?
         Thanks again.
MOtvGuy
MOtvGuy's picture
The light engine is located
The light engine is located inside the set I think?
As for a manual? I can tell you LG manuals are not the best place to obtain part numbers. There are too many versions of sets out there today, the best place to obtain the correct part number is from LG itself.
Another thing. I've never changed an engine in the 44" LCD sets but if those are anything like their 52" DLP sets, the engine doesn't come as a single piece. It comes in pieces that must be mated together. The alignments necessary after re-installation are not for in-experienced, non-technical persons. It is very difficult and time consuming even for a trained tech.
swaydawg
swaydawg's picture
Just replaced bulb and orange
Just replaced bulb and orange light will not go off, is there a reset on the E44W46LCD?
