Panasonic TH-42PD25
Jerry12
Panasonic TH-42PD25
I have a panasonic th-42pd25 plasma television.  It has a 3" black vertical line just left of center.  Does anyone know what is wrong with this set?
You have a bad plasma panel
You have a bad plasma panel or a ribbon cable connector or a bad panel driver IC. This is not the type of set for a do-it-your-self-er to attempt to repair I'm afraid. Most of the time, if there is a bad driver IC, the entire board or panel has to be replaced.  Good Luck
