Mits 65813 bad PIP board
dpturner
 By the way, thank you for your help with my original DM board problem.  I replaced the four bad capacitors with the ones suggested and it worked like a charm -- until the past couple of weeks.  Out of the blue, I developed a "rolling" vertical/horizontal hold problem that would come and go -- on all inputs.  Now it seems to be here for good.  After doing a little research, I've narrowed it down to the PIP module.  There are several "fixes" for this advertised on Ebay -- mostly involving removing the board and bypassing the PIP altogether.  It sounds as if this has worked for many folks.  It also sounds as if changing out the capacitors (like the DM board) might also take care of the problem.  I KNOW I'm not the only one who is having this problem.  You helped me before.  Have you encountered this and do you have any suggestions (diagrams of where the PIP board is and capacitor part #'s would be greatly appreciated).  Thank you for the amazing and money saving advice you are providing for so many.
 David
tsr181
Hello,
Hello,
I have a 4  year old Mitsubishi 65813 that refuses to turn on...as of yesterday.  It has always had the slow green blinking light( a curiosity) ...but as of yesterday it is in super rapid blink mode and it refuses to switch to slow blink mode... so I can not turn the set on.  Is this the capacitor issue?  Would you kindly forward me the repair instructions/diagrams?  My email address is  tsr181@sbcglobal.net.
Much appreciation,
Tom
Only post a problem once Tom,
Only post a problem once Tom, I have seen maybe 6 of these already!
