Sony KP-46WT510 Convergence problem
7 posts / 0 new
Scales
I have a Sony KP-46WT510 with a convergence problem.  I have replaced the 2 ic's and a 5-amp fuse on G board. The bow-tie effect is gone but the colors are still "off".  I did the flash focus on the front panel with no effect and when I go to manual convergence the red will move up and down but not left and right . The other colors move OK.
I did change the ic's before I found the 5-amp fuse blown on the G board.Would that have any effect on the new ic's?Any help would be greatly appreciated.A service manual would also be helpful.
I have checked and double checked the solder points,everything seems to be fine.
Any help would greatly be appreciated. [email protected]
Thorhyde
Did you recheck the 5a fuse?
Did you recheck the 5a fuse? Make sure to check the 3.15a fuses under the ICs
tantan
hello all , how do you
hello all , how do you determine which tube is the red,blue or green? thx.
Johnny b
Is there a service manual
Is there a service manual available for a free download? or a good enough person to share?! Thanks!
Johnny b
Dave2
Johnny b said: Is there a
Johnny b said: Is there a service manual available for a free download? or a good enough person to share?! Thanks!
I have the service manual but how do i get it to you. (8.5+ MB)
Hugg08
We would like to change
We would like to change convergence ic on our KP-46WT510 Do you have instuctions or service manual. We only have the operation manual. Our email is [email protected]
Thankyou
