Mitsubishi blinking green light
Smokey
I have the Mitsubishi WD 62725 television set, that won't power on after a recent power outage. THe green light on the front is blinking, but there is no sign of life from the television set. If you could please e-mail me the service manual at [email protected], or have any suggestions as to what to do that would be fantastic!
Thanks, Greg
Zero
I recently had the same
I recently had the same problem with my Mitsubishi WS 65909 I unplugged it and when I plugged it back in I got a continuous blinking green light. The last time this happened (2 years ago) it cost me $600.00 to get fixed. I got the repair kit from tvrepairkits.com which consisted of 7 capacitors and 2 fuses and "how to" directions. I got to the offending caps and replaced them (THEY WERE NOT BULGED AND STILL LOOKED GOOD) and the set works! Note you WILL NEED the desoldering tool (Radio Shack $11.00) the desoldering wick is imprecise. I found the kit worth the $39.00 because because of the email support and directions (I used it) that come with it.
