You have a mirror that has dropped inside of the light engine or the color wheel is defective. Most likely the mirror is the problem. To repair this, it takes a lot of work. To have it repaired, it will take about 1000 to 1200 bucks. I have a document that explains how to repair this but it is NOT for the novice unless you have a lot of guts and are willing to try. Leave an e-mail address and I will send it to you. Good Luck
Larry Dillon said: You have a mirror that has dropped inside of the light engine or the color wheel is defective. Most likely the mirror is the problem. To repair this, it takes a lot of work. To have it repaired, it will take about 1000 to 1200 bucks. I have a document that explains how to repair this but it is NOT for the novice unless you have a lot of guts and are willing to try. Leave an e-mail address and I will send it to you. Good Luck
Larry, I have more guts than bucks. email me the info at [email protected]
thanks.
I like that attitude! LOL Will do asap. Now , where did i put that list!?
I cannot find that article but look around techlore starting here
