Panasonic TV
15 posts / 0 new
frodo
Panasonic TV
I was wathcing my TV last night and the picture and sound went dead
Checked cable - OK -  Powered down and back up nothing
The TV is a 50" HDTV  Projection (I think) definitely not plasma or
LCD Only 2 1/2 years old
Any ideas of what mihgt be the problem
zapdbf
You need to narrow down the
You need to narrow down the possibilities, do you have sound through other inputs?, Do you have sound through the tuner?. Test this and post back here and maybe we can get closer to your problem.
frodo
No picteure no sound through
No picteure no sound through any of the video inputs
Doesn't even give me an indication that another
video source is on.   I have direct TV - checked the
receiver on another TV - its OK -
zapdbf
No video through other inputs
No video through other inputs? Clarify this. Did you connect a dvd player and try this? This is important to know! Make sure you don't have a mute circuit turned on. or if the set has an external speaker switch in the back that may be flipped to external, i have seen this before. Before we crack the cabinet open, need to make sure it is not something external first.
frodo
I have Satellite TV connected
I have Satellite TV connected to Video Input 1  DVD connected to
Video input 2 -  There is no Video switch on the TV so have to
use the remote to switch.   I get no msg on screen -  none of
the function buttons bring up any menu - nothing.
Switched  the cable to other video input - nothing
funny that both sound and video are not working
if it was pic tube I should still have sound, shouldnt
I?
zapdbf
I re-read your orignal post,
I re-read your orignal post, and for some reason i thought you said you had a picture, and no sound. Sorry. My bad. Sometimes i read too quickly.
let's try this again from this angle. You have no video, no audio, no menu. Do you have a power light comming on ? do you have any light flasing a blink code ?
frodo
When I push power button , I
When I push power button , I get a blinking  green light and the fan comes on.  Shouldn't it go to solid green?    When I push it again blinking red light for a few seconds then
fan goes off.
zapdbf
what you have is a projection
what you have is a projection lcd television. i have not looked up the manual yet, but check for a lamp light and see if it is lit or flashing. If so you have a bad lamp. The lamp is user replaceable. If this does not work count the flashes, it should pause flash a few times then pause again. Count the flashes between the pauses, count them more than once so you can get an accurate number.
zapdbf
the number of flashes should
the number of flashes should be less than 10
frodo
Where is that lamp located?
Where is that lamp located?    I counted the flashes  When I turn it on it flashes
3long flashes  - then it begins a steady fast flashes  I counted 30 and still
flashing.
frodo
I think you are talkin about
I think you are talkin about the projector lamp that slides out of the
front panel?      I took it out and see pieces of glass inside the bulb
looks like its shot.  Would this also account for the no audio problem?
Where do you get replacement bulbs?
frodo
Is the lamp removeable from
Is the lamp removeable from the hosing or do you replace
the whole assembly?
zapdbf
Yes, if the lamp is broken
Yes, if the lamp is broken the tv will not start up and you will not get any audio. the housing the lamp is in gets replaced with the lamp. That is your problem just a blown bulb. Change the bulb all will be well. The bulb is expensive though, not sure how much but it will be in the $200 -300 range.
Good luck
frodo
Thanks a lot for your help -
Thanks a lot for your help - I have located one for $247 on the internet
You probably saved me a couple hundred dollars
zapdbf
expect to change the bulb
expect to change the bulb every 2 years. you  should be able to get the bulb at any local tv store. or try the www.partstore.com. The bulb housing should have the replacement number on it somewhere.
